Re: simple hydraulic question
Posted by rustyfarmall on September 20, 2014 at 12:27:59 from (208.126.186.41):
In Reply to: simple hydraulic question posted by F-Dean on September 19, 2014 at 12:49:33:
NO, the delay is NOT built into the pump. The device for providing the delayed reaction is totally external. It goes onto the hydraulic hose, and is an optional accessorie.
ALL 3 ports are plumbed into the same exact manifold on the rear of the belly pump, and all 3 will do the same exact thing. Take one apart sometime, and you will see.
