Posted by NY 986 on September 20, 2014 at 13:15:45 from (174.236.39.43):
In Reply to: JOHN DEERE posted by davidmelbaseitz@gmail.com on September 20, 2014 at 12:29:57:
You are on an IH board but your issues plague all makes. Most likely a exhaust valve is not opening creating pressure in the cylinder which forces gases past the rings down to the oil pan where the path of least resistance is the vent tube. The valve may not be opening due to being stuck, bent rocker arm, loose rocker arm, or other rocker assembly related issue.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
