Re: H water pump drive pin
Posted by pete 23 on September 20, 2014 at 16:33:00 from (74.33.79.62):
In Reply to: H water pump drive pin posted by riverbend on September 20, 2014 at 15:09:57:
The pin is tapered so it wedges pretty tight. You need to support the back side of driver with a hammer, bar or what ever you can hold against it and then tap threaded end of pin.
