Re: F Dean or anyone on the belley pumps
Posted by D Slater on September 20, 2014 at 17:31:38 from (184.14.168.53):
In Reply to: Re: F Dean or anyone on the belley pumps posted by John M on September 20, 2014 at 16:47:23:
Because they used what IH called a delay lift valve. Small valve that screwed onto the cylinder or outlet to cylinder and the pressure in the system had to build up to a certain point before fluid was sent to the cylinder. May not be exact just going by memory, early ones needed between 200 and 300 PSI and later ones 400 to 500 PSI before the pressure went to the rear lift. By that time pressure was reached the front ones had raised to the end of there stroke.
