Posted by Centex Farmall on September 20, 2014 at 21:47:02 from (72.105.165.95):
In Reply to: MD question from below posted by Joshua Rod on September 20, 2014 at 19:10:34:
The head has three valves. Intake and exhaust like usual and then a small valve that goes to an extra chamber where the spark plug is. When those valves are open, the compression ratio drops making gasoline operation possible. Those valves are controlled by the lever on the side and either stay open or closed. The intake also has a butterfly valve that closes off the main intake when on gas. It forces air to go through a different circuit that includes the carb. There's no throttle control on gas, it runs a steady fast idle.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
