Re: quick disconnects go to what on loader
Posted by SDE on September 20, 2014 at 22:21:32 from (184.158.24.224):
In Reply to: Re: quick disconnects go to what on loader posted by xpkson on September 20, 2014 at 19:40:21:
Each lever will control two QDs, if it is set up for dual action. You should have two cylinders to raise the loader. These two lines may be connected to a Tee and then one line goes into a QD. That one will raise it. If you want down pressure, you will have two more lines, again connected to a Tee, and this line will connect to the other QD that is controlled by the same lever, when it is pulled or pushed the opposite direction.
The other two QDs are controlled by another lever Again you will have two cylinders on the bucket. Each cylinder will have two hydraulic lines. One to lift and one dump. Each of these lines will connect with one from the other cylinder at a Tee and that one line will go to a QD.
You have two levers that control two sets of QDs. one set to raise and lower the loader and one set to control the bucket
SDE
