Re: 3 pt hydraulic connections
Posted by Used red mn on September 20, 2014 at 22:42:35 from (198.228.228.153):
In Reply to: 3 pt hydraulic connections posted by farmall_h_1944 on September 20, 2014 at 19:49:50:
Since you say your not sure of the in and out of your valve I'd
say the arrows on your photo are wrong. I'd say what you say
is "out to pump" is pressure supply into the valve. The line you
say is "in from side of tractor" is actually the oil out of the valve
returning to the resivoir. Is that a hose splice in the dark part of
the photo behind the tail of the bottom arrow? If so it looks like
the pipe you did not label is the "pressure down" side of the
valve set up to dump into the return line at the tee So I would
say the valve is set up for "single action" or one way as you
call it. The line you call "out to loader" would go to the lift port
of the 3 point cyl. The line you say is not shown is the "suction"
or the feed for the PTO pump. Please know that this is posted
based on 90% guess and 10% IDK. As for using the belly
pump only you will have to get that info from another poster. I
will say it would most likely lift less that way due to the lower
psi output of the belly pump.
