Re: 3 pt hydraulic connections
Posted by D Slater on September 21, 2014 at 05:14:48 from (184.14.168.53):
In Reply to: 3 pt hydraulic connections posted by farmall_h_1944 on September 20, 2014 at 19:49:50:
Need to be there to say for sure. But looks like the spool valve is already plumbed to use single acting. That's the reason for the two lines teed.
Out to loader one goes to the 3 point lift cylinder. One marked out to pump to a side port opening if using the liftall unit. Need to keep the liftall operating rod locked back for use with your valve. Teed line to liftall drain port with a tee and plug.
Or for single acting all you need is a line to a side port on the liftall unit.
Advantage with that is simple and if the unit checks don't leak the 3 point won't leak off unless the cylinder bypasses.
Disadvantage is with a heavy load its hard to control the pressure release and drop with a heavy load on the hitch. Also you won't have the 2 ports unused now for another hydraulic cylinder us if wanted sometime. They can be used with a double acting cylinder if wanted.
