Re: F Dean or anyone on the belley pumps
Posted by D Slater on September 21, 2014 at 05:57:42 from (184.14.168.53):
In Reply to: Re: F Dean or anyone on the belley pumps posted by John M on September 20, 2014 at 16:47:23:
third party image
John if you stop the video at 5:32 and look toward the battery the delay lift valve is on top of the cylinder. Has the hydraulic line coming forward then hooked to the delay lift valve. Valve makes a 90 into the cylinder opening and has a cap on the forward end.
Adding another picture of pump cover. Red line covers the oil out of pump gears channel shown in a previous picture and shows end of pins that push check balls off there seat. Also shows the hole that is open to sump when not pumping or closed for pressure to the check ball openings.
