Re: What 12V battery fits in SA bat box?
Posted by snoop on September 21, 2014 at 11:59:21 from (67.213.35.68):
In Reply to: What 12V battery fits in SA bat box? posted by WellWorn on September 21, 2014 at 11:19:35:
Check measurements of a Group 24 or a Group 24F for dimensions to fit your box and note also which post alignment would work easiest for you. A slim possibility would be a group 22.
I'm going "off fading memory" here, but hopefully this will get you started. Good Luck!!
