Re: Farmall BN no spark
Posted by spf150 on September 22, 2014 at 05:42:02 from (67.252.117.72):
In Reply to: Farmall BN no spark posted by mkirsch on September 22, 2014 at 04:47:00:
When I turn it one way there is a resistance with the spring and a definite WHACK if you keep turning. If you turn it the other way it is much easier and you can feel some resistance with the magnets.
Gonna try replacing the points today and test it on the bench. If that doesn't do the trick the only other thing left to do is the coil, correct?
