Re: bad injectors?
Posted by dej(Jed) on September 22, 2014 at 09:19:36 from (141.189.113.1):
In Reply to: bad injectors? posted by reggie1086 on September 22, 2014 at 08:39:10:
I have a diesel fuel hydraulic test rig that I can hook one injector up to. I pump it up by hand and check the pop off pressure. (It has a gauge on it.) At the same time I place a white paper towel under the nozzle end. I was taught that you should get a circular spray out of the nozzle. The spray should be even and if it isn't , you need to remove the injector tip.
You can then clean it in a sonic cleaner and reassemble it and test it again. If necessary repeat the process untill you get a nice circular spray at the pressure required for that injector.
The testers aren't too expensive.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
