Re: timing a farmall C magneto
Posted by Chesterton angelo on September 22, 2014 at 10:27:53 from (70.194.135.134):
In Reply to: timing a farmall C magneto posted by gene bender on September 22, 2014 at 10:14:17:
Gene- how do you time the gear that runs the mag? Also I thought that I would want the mag loaded so that when I pull it away from the tractor and it clicks, it will be timed right? Maybe I am just missed understanding youm
