Re: bad injectors?
Posted by Dieseltech on September 22, 2014 at 10:58:44 from (98.206.80.148):
In Reply to: bad injectors? posted by reggie1086 on September 22, 2014 at 08:39:10:
If the filters and fuel cap vent is OK the one way check valve in the bottom of the tank that the return line goes to may be plugged or restricted with old flex ring bits from the pump. A quick check is to loosten the timing cover screws next time it acts up, if it speeds up and sounds better the return needs attention. Happens to any Roosa/Stanadyne injection pump, worth a look.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
