886 IPTO
Posted by el6147 on September 22, 2014 at 11:09:09 from (50.105.93.211):
third party image
I have never replaced a IPTO shaft on a 886 or similar tractor , splines are worn , will the three bolt housing (pictured) remove from the front with out removing the surrounding housing and bolts and without splitting the trans from the rear end ?
Ih dealer said it can be done and the IT manual is vague about the procedure.
the three bolts are removed but the housing doesn't seem to loosen any when pried on or taped with a hammer . there appears to be a black RTV sealant that was applied before it was assembled before , that maybe all that is holding it .
I really don't want to open something up that I can't reassemble without splitting it again or removing the cab to do so . thanks
