Re: Magneto and distributor gear timing
Posted by AlanA on September 22, 2014 at 13:54:50 from (108.65.83.248):
In Reply to: Re: Magneto and distributor gear timing posted by agauthier on September 01, 2014 at 11:29:43:
OK, she purrs like a kitten now. Went out there by myself, early in the morning, nothing in a rush. Evidently the problem was being sure I was on #1 TDC compression. I pulled the valve cover off, turned it til both #1 valves were close, moved it on up to the timing mark, and followed the rest of the drill. She started on the 2nd pull. 8) 8)
Thanks for all your help on this!
