Bring the #1 piston up on compression, then back in up till almost dead bottom. Turn the mag so the rotor is going to be at #1 plug tower when it snaps. Then install the mag, you will have to turn it to match the gear slot. Bolt it down with the bolts in the center of the hole slot. Then slowly turn the engine the right way, and watch the timing marks when the mag snaps. If it too fast, bring #1 up a little more, and try it again. Its called trial and error, but that's the way I do it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
