Posted by Lmack on September 22, 2014 at 18:04:58 from (24.131.50.165):
In Reply to: Flat belt advise posted by Dr. Bert on September 22, 2014 at 17:32:17:
You do not want to let the "guide" keep the belt on but you absolutely have to get the pulleys lined up. That does not mean that the shafts have to be level as there are times the shaft you are driving could be vertical. The belt will adjust to shafts that are out of level and it can be a lot. It will take some trial and error but the first time you start it up watch the belt (go slow and turn it only a little) and see if the belt tends to run off. If it does you got to shut it down and move the drive pulley in the direction of the run off. Do this until the belt stays centered on both pulleys. If you let the belt touch the guide it will fray and destroy the belt in short order.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
