Re: Priming oil pump
Posted by pete 23 on September 22, 2014 at 18:17:58 from (74.33.79.62):
In Reply to: Priming oil pump posted by Joshua Rod on September 22, 2014 at 17:00:45:
A pressurized oil tank is always a good idea, but very few repairmen use that system. As the oil pump sits right in the oil priming is not a problem on that engine. I leave spark plugs out so engine spins much faster and easier. Then I use like 10 second bursts and minute or so rest with starter until I have oil pressure. If that does not bring you pressure you are not ready to try starting engine.
