Re: 200 Stuck Clutch
Posted by CharlieNJ on September 22, 2014 at 18:56:30 from (174.57.216.64):
In Reply to: 200 Stuck Clutch posted by Lmack on September 22, 2014 at 17:53:54:
third party image
Lmack, the picture is of a battery explosion I had not long ago. I put some sticks in it to show how it split, it naturally blew the caps off too, but they are back on in the picture. I blew up a battery one time about 30 years ago, but it did not make the noise this one did. Strange part was I did not even make a spark. Found out the regulator failed and the alternator was putting out 16 volts steady. Well, after 2 hours of mowing I shut the tractor down for several minutes, when I went to restart it...KaBoom.
Sooo, I won't chew you out, but will remind you to be careful!
Best Regards,
Charlie
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
