Re: Priming oil pump
Posted by teddy52food on September 22, 2014 at 20:16:09 from (184.94.175.179):
In Reply to: Priming oil pump posted by Joshua Rod on September 22, 2014 at 17:00:45:
If you used a good assembly lube when you put it together, just start it up & watch the gauge. It takes a little while to fill the filter but should have full pressure soon. Just think, every time you shut it off, & start it again, it has to run a while to get up full pressure too. And that hot oil drains off way more than a good assembly lube.
