farmall 200 carter carb
Posted by dewy on September 22, 2014 at 20:43:11 from (72.152.228.239):
no.37 on diagram idle adjusting screw..whats good setting to try and get running..just put carb on after cleaning,found under seat...it is the first carter carb on messicks diagram ..its the only adjustment on the carb...if i screw all way in. how many times out should i start with... thanks for any help......dewy
