Re: 460 utility cold blooded?
Posted by mkirsch on September 23, 2014 at 05:21:12 from (72.45.143.81):
In Reply to: 460 utility cold blooded? posted by Eric Allen on September 22, 2014 at 19:18:11:
If you're using starting fluid, either you're not using the choke or something is definitely wrong.
Yes, the 6-cylinder engines are cold blooded, but not THAT cold blooded. You'll need to fiddle with the choke for the first 5-10 minutes until they start to get warmed up, but spray should not be necessary.
These aren't fuel-injected, which throws a lot of people who didn't grow up on a farm operating these machines for a loop. You need to learn to use the choke and develop a feel for what your particular tractor "wants" as each tractor is a little different.
Top tip: Don't let the clutch out without one hand on the choke knob after you first start it.
If choke doesn't help, start with a compression test.
