Re: C still loses power
Posted by gene bender on September 23, 2014 at 05:26:14 from (67.55.226.121):
In Reply to: C still loses power posted by PretendFarmer on September 23, 2014 at 05:16:06:
Are you using the stock mag or has it been changed to a dist. Replace the gov spring with one for a 240 and make sure the gov housing input shaft doesent have slop and then set the carb linkage correct. What size tores are you using they could be way too much oversized. Hard to tell what others are using as the term "stock" is widely abused too many internal things can be changed in that engine.
