Re: 200 Stuck Clutch
Posted by mkirsch on September 23, 2014 at 05:40:35 from (72.45.143.81):
In Reply to: 200 Stuck Clutch posted by Lmack on September 22, 2014 at 17:53:54:
You didn't necessarily have it hooked up incorrectly, with regards to polarity. Some will say jumping a 6V off a 12V is incorrect as the day is long, but not me. A 6V battery charger on the "boost" setting puts way more voltage into a 6V battery than any 12V battery can.
A flat dead battery will cause excessive current flow through the jumper cables. If they're not real heavy duty cables, they will get hot.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
