Re: 300 utility bearings
Posted by Harry Klever on September 23, 2014 at 06:24:41 from (65.23.185.129):
In Reply to: 300 utility bearings posted by nj tom on September 22, 2014 at 16:49:01:
i didn't mean to imply that u can remove the crankshaft with out removing the motor, first i would do is a compression check, with the throttle in the advanced position and like Pete and Teddy said check the oil pump bottom plate first, If it's got a grove that u can feel, take it to a machine shop or replace!
