you need a complete tune up , including carb job and valve adjustment and adjusted to factory spec's. mine started with 1 turn of the engine with choke pulled right out once this was done. it was very easy starting tractor. but just had to keep some choke on in cooler weather till it warmed up. who know's, maybe your choke is not closing all the way? also you need the heat riser valve working, but it has nothing to do with starting.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
