Re: 460 utility cold blooded?
Posted by Charlieu on September 23, 2014 at 10:43:15 from (206.8.2.16):
In Reply to: 460 utility cold blooded? posted by Eric Allen on September 22, 2014 at 19:18:11:
Do you still have the resistor bypass wire hooked up and is in working? From the factory those tractors had a wire that came off the starter solenoid that hooked to the Pos (+) terminal of the coil allowing full battery power to reach the distributor points for starting. Once the engine was running power flowed from the ignition switch to the resistor (beside the coil) to the distributor, allowing about 7 volts to reach the points for normal running. I have seen tractor where the coil and resistor were replaced with a 12 volt coil, and then the extra voltage for starting is not there. Charlie U
