Re: Priming oil pump
Posted by mkirsch on September 23, 2014 at 11:39:02 from (72.45.143.81):
In Reply to: Priming oil pump posted by Joshua Rod on September 22, 2014 at 17:00:45:
What difference does it make if you are grinding it with the starter or it's grinding under its own power? It still takes the same number of revolutions to build the oil pressure and the same amount of wear and tear is incurred.
