How fresh is the gasoline? Summer blended fuel that has aged in the tank will have evaporated off some of the more volatile parts of the fuel making what is left harder to vaporize. Try adding a couple gallons of fresh gasoline to see if that helps.
I have not added any gasoline to my 2444 since June. I expect that as the temperature drops I will be having problems getting it started with a cold engine. I happens almost every fall. Adding a couple of gallons of fresh gasoline always makes the problem go away.
This post was edited by Owen Aaland at 12:19:33 09/23/14.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
