I thought you were talking about a "Farm Hand Loader" but wasn't sure about what I could offer because I am familiar with the "High Lift" model which we have. Only ours has been modifyed a couple times from the way it was originally to be more like yours which may be stronger. Cylinders were originaly longer and on the outside of the tires and a massive structure over the tractor. Not sure why it was modifyed but there must have been a thought process that it would be an improvement. I have new cylinder tubes that were cut off once when the cylinders were replaced and shortened. We have a hugh manure scoop and a bucket to lift hay bales in a group from the top way up on top a stak, plus the round bale forks you will see in the pictures. The pump used to be PTO driven but now is mounted on the side of the engine so it is live hydralics. Capacity is how much you can lift before the front wheels get flattened out to much to steer and the back wheels start comming off the ground. We have upset it a couple times but came out safe because of the protective structure. A little crude but a great machine. cleddy
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
