It has been about 40 years since the recommended plug was a D15Y instead of the D16. The heat range is one step colder but the extended tip more than makes up the difference. With the leaded gasoline being phased out the recommended plug for most duty became the D18Y with the D15Y still recommended for heavy loaded engines or the D21 if used with light load use only.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
