Re: Can this float be fixed??
Posted by Lmack on September 24, 2014 at 12:51:45 from (24.131.50.165):
In Reply to: Can this float be fixed?? posted by IAtractorKid on September 23, 2014 at 17:17:59:
No do not waste your time. I know others have said go for it but the extra weight the weld will add will alter how the float works. You may not be happy with how it works after the repair. It will certainly make the level in the bowl deeper and could cause the carb to flood if the level is maintained too high.
