Super C lift
Posted by Donnie Redding on January 03, 2001 at 16:59:36 from (216.207.62.99):
I have a 1954 Super C with the factory two point hitch. The lift will not work. I have cleaned the filter in the housing and changed the fluid with hy-tran fluid. I left the fill plug off with the tractor running to remove any air. Do you any suggestions on where I need to start in order to get it going. Thank you for your time.
Donnie
Post A Followup
: Re: Super C lift
