Re: Farmall 560 Gas Died On The Road
Posted by DGinVT on September 25, 2014 at 05:27:13 from (75.105.0.39):
In Reply to: Farmall 560 Gas Died On The Road posted by CTPhil on September 25, 2014 at 05:05:19:
make sure when you removed
the bowl plug that you have a steady stream of gas coming out and that it does not slow down. There still may be dirt in the tank or the gas filter partly plugged. Also remove the cap on the gas tank and see if that improves the flow. the vent in the cap can plug causing little or no gas to flow. Also check for a good bluish white spark from the coil.
