Re: Can this float be fixed??
Posted by jeffcat on September 25, 2014 at 18:26:35 from (69.244.99.202):
In Reply to: Can this float be fixed?? posted by IAtractorKid on September 23, 2014 at 17:17:59:
First clean the brass with "Bar keepers friend" Make every thing nice and clean.I use radio solder cause it has a lower melt temperature. It is 60/40 lead tin so don't breath the fumes. I use the solder paste that depot sells for plumbing. White and green tin can. JIG everything up so when you hit it with a low wattage solder iron you do not mess up. Should be a snap. Jeffcat
  Upload Photo  Select Gallery Photo  Attach Serial No List
