Re: IH Pull type combine
Posted by gene bender on September 26, 2014 at 03:39:02 from (67.55.226.121):
In Reply to: Re: IH Pull type combine posted by El Toro on September 24, 2014 at 13:45:39:
Why need a flywheel if it has starter and combines did have a clutch balers did not use a clutch.
  Upload Photo  Select Gallery Photo  Attach Serial No List
