Re: Farmall M External Resistor Getting Hot
Posted by mkirsch on September 26, 2014 at 04:52:01 from (72.45.143.81):
In Reply to: Farmall M External Resistor Getting Hot posted by johnb5345 on September 25, 2014 at 21:59:07:
Do you have the resistor connected correctly?
It should get hot, because that is what a resistor does, but it should NOT smoke.
The wire should run from the ignition switch to the first terminal on the resistor. From the second terminal to the + on the coil. From the - on the coil to the post on the side of the distributor.
