Re: Farmall M External Resistor Getting Hot
Posted by Janicholson on September 26, 2014 at 08:37:31 from (199.17.6.25):
In Reply to: Farmall M External Resistor Getting Hot posted by johnb5345 on September 25, 2014 at 21:59:07:
The reason the resistor gets hot is as stated below (it needs to get hot to work) the reason the ignition should not be turned on while not running is that almost all engines stop with the points closed. Thus when turned on and not running, the full draw of the coil and resistor is placed on the system continuously. When running, the point closed time is about 50% on 50% off (Dwell). This results in the coil and resistor and points only having current flowing one half the time. This allows the devices in that circuit to cool half the time. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
