Re: No gas
Posted by El Toro on September 27, 2014 at 08:51:01 from (96.244.7.206):
In Reply to: Re: No gas posted by farmall4856 on September 27, 2014 at 05:52:38:
Disconnect the gas line at the carburetor use a clean container to catch the gas. Should see a full stream of gas from the tank.
If you have a full stream of gas remove the tube fitting where your gas line connects. There may be a screen behind that tube fitting that's plugged with crud. Also make sure your main jet adjusting screw is opened enough. Hal
  Upload Photo  Select Gallery Photo  Attach Serial No List
