Re: O.T. - Source for large thrust washers???
Posted by Lpakiz Larry on September 28, 2014 at 08:17:45 from (184.61.192.47):
In Reply to: Re: O.T. - Source for large thrust washers??? posted by Harry Klever on September 25, 2014 at 18:07:16:
I have had great luck using hole saws to make large washers.
Trick is to turn the drill press as slow as possible, and use cutting oil. Clear the chips frequently. Saw the large diameter first, because you need the pilot hole for the smaller cut, too.
These are just hole saws available at the hardware or big box farm store. Brands are Lenox, Ridgid, etc.
I have some hole saws that have cut thru the combined equivalent of 20 inches or more of steel. 1/2 inch thick can be sawed
  Upload Photo  Select Gallery Photo  Attach Serial No List
