Posted by Notjustair on September 28, 2014 at 19:30:29 from (174.229.64.78):
In Reply to: Re: 560 gas motor knock posted by Brad Vaughn on September 28, 2014 at 14:10:48:
Get it hot so the oil thins a little then listen to it. If it knocks when you load it up or when you throttle it up quick it is a rod bearing. At least in my experience. I had one that I didn't notice when using but after it was hot (like when you were parking it) it knocked like Thor's hammer at idle (lower oil psi) and really bad when you throttled it up, too. The crank was totally toast on that one not just the bearings. Have it pull a hill and it will knock as well. Main bears are deeper down - more of a rumble. Rod knock makes it sound like a diesel if it is all of the rod bearings worn out like mine was.
Do something about it before you have a rod make an escape attempt or the crank is too abused to reuse. If it is knocking the crank will need ground.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
