Re: 560 gas motor knock
Posted by John A on September 28, 2014 at 21:33:02 from (64.128.16.238):
In Reply to: 560 gas motor knock posted by Brad Vaughn on September 28, 2014 at 13:28:44:
Brad, Drop the Pan and Inspect the bottom side!!
15 minutes, Drain the oil, A 3/8 air ratchet /w a 9/16 socket, a rubber hammer to tap right smartly on the oil pan and it is off and you can put a visual inspection on that 263 IH gas motor! If a piston skirt or any thing else has broken off it will be in the bottom of the pan .
Wash out the pan with Gas, also drop oil pump and wash out the screen, dump out the mixture of gas, oil, sludge, and other nastiness but the last part look for metal filings in the bottom of the pan that would be a tell-tale sign of problems. Do not run it more than you have to, If a piston skirt has broken off! A good honing might correct the cylinder so only a new piston is needed! Hope this helps!
Later,
John A.
  Upload Photo  Select Gallery Photo  Attach Serial No List
