Re: Ethanol based fuel
Posted by mkirsch on September 29, 2014 at 05:36:33 from (72.45.143.81):
In Reply to: Ethanol based fuel posted by mikesbailey on September 27, 2014 at 16:31:55:
People just love to blame ethanol for everything from poorly running engines to toothaches... If you can't explain it, ethanol caused it.
The long and short of it is, your tractor doesn't run right because you still haven't got the carburetor completely cleaned out, or it's put together wrong, or it's set wrong.
Carburetors don't look very complicated and it seems like you can just rinse them out and slap them back together any old way and they should work... Sometimes you have to take them apart 3-4 times to get them working right, even if it seems like you didn't do anything different.
