Re: Farmall H width
Posted by DeltaRed on September 29, 2014 at 08:18:17 from (67.40.59.72):
In Reply to: Re: Farmall H width posted by Leroy on September 28, 2014 at 15:34:34:
Leroy,you are mistaken.Tractors were set up for the most common conditions/requirements of an area. In the midwest,Farmalls were dished out to accomodate a 38" corn row.In areas where narrower rows are used,they must be dished in to be narrow enough to fit.The load is centered on the center of tire.In fact,the only time I've ever encountered a broken axle was on a 300 with wheel disked out.
  Upload Photo  Select Gallery Photo  Attach Serial No List
