CT not to insult you but I have no idea of your level of mehanical knowledge. The impulse mentioned in a magneto is a spring mechanism on the drive that should make a clicking noise at cranking speed. It stalls the mag shaft then releases it when a cyl is at the firing point. This release allows the magnetic coil to release a higher voltage spark as the mag shaft spins quickly past the firing point. When the engine starts centrifical weights disable the mechanism and the mag goes to direct drive if you will.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
