Re: Farmall H belly pump run a log splitter?
Posted by mkirsch on September 30, 2014 at 08:10:59 from (72.45.143.81):
In Reply to: Farmall H belly pump run a log splitter? posted by PretendFarmer on September 30, 2014 at 06:18:27:
A belly pump *WILL* run a log splitter, if you don't care how fast it goes and only split straight-grained wood.
It depends on what you want. If you're older and don't move so fast speed may not matter. If you're younger and you want to bust up as much wood as quickly as possible to get the job done, you will not be happy with the belly pump.
If you have the Charlynn pump, use it. It is about twice the PSI and twice the GPM of the belly pump.
