Start with the battery posts and cable connections.
1. It is FREE, or at most a few dollars for a battery post cleaner tool.
2. It is EASY. No heavy lifting or big bolts to remove.
3. It is most likely your problem. Starters do not instantly go bad, or go bad from sitting.
We had this exact problem last weekend with the Super C. Dad was SURE the starter burned up. After we took the starter off, took it all apart, fiddle-farted around, put it all back together, and tested it with a battery and jumper cables, it worked fine. Put it back on the tractor and... NOTHING.
Bypassed the positive cable with jumpers, and the tractor popped right off and ran like a top. 30 seconds of scrubbing the + terminal and + cable clamp, and it worked like new again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
