Re: Farmall 300 coolant in oil
Posted by Farmall300IH on September 30, 2014 at 09:51:12 from (66.41.200.105):
In Reply to: Re: Farmall 300 coolant in oil posted by mkirsch on September 30, 2014 at 08:27:12:
It was a relatives tractor that was parked because there was no longer a use for it. It was running fine when it was parked.
Is it possible that a cracked block would allow all of the coolant to pass through into the crankcase? The oil almost seemed like it was under a bit of pressure when I pulled the plug
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
