Re: New Member with a farmall A
Posted by El Toro on September 30, 2014 at 13:41:27 from (96.244.7.206):
In Reply to: New Member with a farmall A posted by gary1213 on September 30, 2014 at 11:55:08:
third party image
If the tractor wasn't sheltered I would check the oil pan & gear boxes for water. I would check some of the rod and main bearings. Check the crankshaft too.
In 1975 I bought this Farmall A for $100.00 along with the 16-inch moldboard plow. The engine was stuck. It needed tires, rims, steering wheel, wiring, fenders and seat. I pulled the engine and steam cleaned the block. I
removed all the pistons, sleeves and crankshaft.
I installed a new sleeve kit, had the crankshaft
polished, new bearings, tires & tubes, new seat and used fenders. New wiring too. Then I plowed my garden. Hal
PS: I removed a lot of crud under the old
sleeves.
  Upload Photo  Select Gallery Photo  Attach Serial No List
